nate-costello avatar image
nate-costello asked
AC to DC Conversion Efficiency for Victron Inverter/Chargers
This document describes inverter (DC->AC) efficiency vs power for the Multiplus: https://www.victronenergy.com/upload/documents/Output-rating-operating-temperature-and-efficiency.pdf
As I'm designing my system, it would also be useful to know efficiency for (DC->AC) so I can size the equipment that will provide AC to the Multplus. I know I could assume the same values/curve as DC->AC, but I also recognize they could be quite different. Does anyone have any resources on this subject?
MPPT ControllersMultiPlus Quattro Inverter Charger
As far as I know the same hardware that convert DC to AC is used to convert AC to DC.
So I would say the efficiency should be nearly the same.
