I have a multiplus 12/3000/120 and was thinking of connecting the AC out 2 to 1 breaker in the breaker panel. Is this possible or do I need to move that to a sub panel? How would I connect the AC wires?
You need separate sub panels on each AC output.
You can't connect the two outputs to breakers in the same panel because that would essentially tie them together.
You also can't connect either of the inverter AC outputs to breakers in the same panel receiving shore/grid power (what would feed the input to the inverter) for the same reasons.
Actually it would really not be a subpanel would it? My plan is to go from the AC out 2 on the multiplus to the new panel which would have the 1 breaker for the circuit I want to attach to the AC out 2 of the multiplus. ! more question is where would I get the ground wire for the panel I add, should I run 1 from the other panel?
15 People are following this question.
