david-123 avatar image
david-123 asked
Reset Multi-plus with dip switches How?
Is it possible to reset the multi-plus to stand alone by the dip switches.
When i connect the battery power and switch it on it brings up an overload, if i then change the dip switches to factory reset, and press the save button nothing happens.
Have i got the sequence wrong, or can this only be done by computer and the link?
Alexandra avatar image
Alexandra answered ยท
@David 123
The mk3 is your easiest option. You can run right through your dip switch settings again to reprogram all the way as well.
Unless you have a GX device you can't do it over the vrm
A software update will reset all settings. But you will also need the mk3 unless your dealership will do it for you as a courtesy.
david-123 avatar image david-123 commented ยท
Thanks Alexandra I will just have to buy a mk3 I have had these multi-plus's 15 years The master works fine on its own.
0 Likes 0 ยท
