adamjones avatar image
adamjones asked
Multiplus Compact 24/2000/50 possible burned fuse
Hi! I own a MultiPlus Compact 24/2000/50. Lately I had a problem with charging the batteries from the generator (it kept disconnecting) , which is strange because it has been working for 2 years. So, I was trying to find online solutions, and I have seen that you can make the setup trough a PC and an ET-cable. My mistake, I do not own a driver and I have connected for like 10 sec the multiplus to my laptop and I think I might have burned a fuse. A bit of smoke went out and now it only connects for 5 seconds and then it disconnects. What should I do? I know that in some cases of burn out the fuse might recover in some hours, otherwise should I try to change it? Any help is welcome, as soon as possible, thank you!
5 comments
@adamjones
When you say you plugged your PC into the multi using the Ethernet cable, did you have a device in-between or was it directly linked?
adamjones avatar image adamjones Alexandra ♦ commented ·
it was directly linked with no device in-between, that's the problem, i guess
Alexandra avatar image Alexandra ♦ adamjones commented ·
Yup that will do it. There is a device used when connecting for programming. Your next step will be to take it in for repairs.
so there isn't anything that I could do myself, right?
As far as I am aware no, sorry
