Justin avatar image
Justin asked
Multi Plus Compact - in Passthru mode ?
hi there,
we have a MultiPlus Compact 12/1200/50-16 that seems to be stuck in passthru mode once it completes the bulk charge and never gets to Float and storage this site is slightly different where is has a Energy Meter ET112 to keep track of the AC input power used as we need to power for the grid power used
thoughts on how this can be fixed ?
thanks
If you disable the Grid Meter does it leave passthru mode after 10 minutes or a restart?
The causes of Passthru are usually addressed by one of the issues in Question 4 of the ESS FAQ.
9 comments
Justin avatar image Justin commented ·
hi Guy,
thanks for your reply can to tell me how to disable the Grid meter ? can this be done from the CGX ?
Daniël Boekel (Victron Energy Staff) avatar image Daniël Boekel (Victron Energy Staff) ♦♦ Justin commented ·
Hi @Justin
you can do this in the ESS-menu (yes in GX device, either on screen or with remote-console)
Justin avatar image Justin Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
thank you i'll log in via the remote console from the VRM and have a look
Justin avatar image Justin Justin commented ·
does this look right ?
Alexandra avatar image Alexandra ♦ Justin commented ·
@Justin it seems that you do not have ESS assistant programmed on your inverter.
Try on the CCGX in the Settings → Energy Meters menu
I don't think you can software disconnect it from there though
Justin avatar image Justin Alexandra ♦ commented ·
do i need to enable ESS on the multiplus ? - what effects will it have ?
do i need a firmware update ? all we use the energy meter for is calculate the total power used as we are on another companies power feed and we have to pay them for power
Is this a new set up? Do you have solar in your system? And what batteries and charge profile do you have?
I can't see how adding a meter could change a charge behaviour.
Not a new setup and there is no solar on this setup ..
Same battery profile i have used on all my other sites without an issue (but this is the only one with a Grid Meter)
