I have 4s6p lifepo4 battery pack - 12v, has bms(4s 12v 45A)
I have solar panel 42w 24v - nominal current 1.25A, nominal voltage 33v max design voltage 65v
I need advise on what mppt will be the best to choose.
Please advise.
Thank you!
Please advise.
Thank you!
The smallest will work for you. Smartsolar 75/10 if you want bluetooth or bluesolar 75/10 if you don't care about monitoring. I have a portable system with two 20w panels that is basically the same setup you have. I went smartsolar 75/15 because its the same weight as the 75/10 and I already have a 75/15 and the portable one can also serve as a backup for my main unit.
Hey man, Thank you! I got the 75/10 with BT. I am sure i will use it for something bigger when the project will grow up.
Hi, you can check it out with the victron MPPT setup file:
https://www.victronenergy.com/upload/software/VE-MPPT-Calc-3_6.xlsm
17 People are following this question.
