Matt drummond bell avatar image
Matt drummond bell asked
Genset to paralleled multiplus 48/5000
Just got hold of an ex mod genset, to use as standby for off grid system, it has 2x 45a outlets, each ran off of same single phase , on separate breakers .now , can I run each outlet to each inverter or do I swap out the 2x45s for a single 90 and just use single cable to feed inverters? What happens if one outlet trips and the other is still feeding just one inverter? Thinking of the symmetry of it all!
many thanks matt
wiring
