bill avatar image
bill asked
Blue Smart IP22 Charger Configuration
Hi there,
I just wanted to check that the 'Blue Smart IP22 Charger' can charge Two 'Relion 100ah LifePo4' Batteries at the same time? If I run them in Parallel, do I just feed the cables to one battery?
Also I have a Victron 'SmartSolar MPPT 100/30' Can this charge simultaneously with the IP22? I am also using the Victron 'Battery Monitor BMV-712' trust this is all compatible?
Thanks a-lot for your help.
battery charging
nairbbrian avatar image
nairbbrian answered ·
Same problem, i am connecting the charger to the same terminals as the smart solar mppt. I am setting charger the bulk voltage slightly lower than the mppt so as not to interfere with the solar charging if the sun begins to shine.that is my idea ?
