tacosolar avatar image
tacosolar asked
Victron Connect wants to install Firmware 1.50 to MPPT100/30 twice: 1st to MPPT100/30, then to BlueSolar
Hi, I'm new to this forum and Victron devices.
I have a relatively new (3mo.) MPPT 100/30. Just went to check status with Victron Connect on my Mac running Mojave and the MPPT 100/30 required a firmware update.
Victron Connect showed correct 100/30 device and firmware version info so I proceed with the update. It appeared to install the FW correctly but when I reconnected after update the Victron Connect software put me back in the update sequence, but this time it showed an icon and firmware versions for the BlueSolar device - not the MPPT that I have.
I was reluctant to proceed but the Victron Connect SW would not let me connect w/o the 2nd update to the erroneous hardware. So, after scouring the internet for advice, with fingers crossed I went ahead and applied the second firmware update.
After that Victron Connect allowed me access to my MPPT 100/30 and seems to be functioning correctly, showing data, etc. Has anyone experienced this?
Why would the MPPT 100/30 ask to update firmware twice: 1st to it's correct HW/FW version then to a version for a different device (Blue Solar…)?
Thanks!
firmware update
The first update was for the internal Bluetooth adapter and the 2nd was for the MPPT itself.
