moritz avatar image
moritz asked
MPPT 75/15 Low output
Hi all,
I recently installed my 160W SemiFlexiable Solar Panel and the MPPT 75/15 on my car.
I have checked eveything and eveything seems to be fine.
But when I take a look in the app the controller is not really charging.
It always shows something like 6 - 12W (even in full, bright sun with clear sky).
Things I already did:
- Measured voltage on panel (20 - 21 V)
- Measured Volage when conntected (see app)
- Measured current if conntected to the MPPT 75/15 (same result as in App)
- Started some usage on the battery (battery voltage goes dosnt but current not up).
- Performed a factory reset
- Checked fuse
- Removed solar panel and battery -> reconnected battery then solar panel
Any suggestions what might be the problem?
Thanks,
Moritz
MPPT Controllers
Guy Stewart (Victron Community Manager) answered ยท
Can you disconnect the panel and see what the solar voltage shows in the app?
4 comments
moritz avatar image moritz commented ยท
Thanks for the answer, I have tested it and the app shows a current of 0.01V
0 Likes 0 ยท
Can you take a screenshot of the battery settings screen?
And the same status screen with the panel disconnected.
0 Likes 0 ยท
Very strange, I went to the Car and connected via App to shoot this screenshots:
As I connected the panel again it shows something like this:
It shows about 50W which seems to be not much for a 160Wp in direct sun. Shout that be more?
Thanks,
Moritz
0 Likes 0 ยท
Should be more, but why.
Could be a bad connections somewhere,
Also would be a good idea to read this recent similar post, and do the same maths on your panel to make sure the numbers add up:
https://community.victronenergy.com/questions/49997/solar-current-during-bulk-much-lower-than-open-cir.html
If you get stuck, post a photo of the spec sticker on the back of the panel.
0 Likes 0 ยท
