Hi @Simon Jenje
What does your 'services' menu look like? what firmware version are you running in the Venus GX?
it should look like this:
you can also test functionality if you have a computer connected to the same network, and browse to the GX ip-address + /app:
Hi Simon, so if you enable MQTT?
Also up to firmware 2.54 (fixed in 2.54 now) there was a bug where when 'vrm two way communication' was enabled, and no internet available, the VRM app could 'break'
https://www.victronenergy.com/blog/2020/05/25/venus-os-v2-54-adding-the-24v-pylontech-up2500-battery-and-more/
Fix “Could not connect to the MQTT server” bug in the Marine MFD App, aka Glass bridge integration. It worked well in most systems, but not when “VRM Two Way Communication” was enabled in a system without internet connection. Now, even when there is no internet, enabling that setting does not cause any issue.
13 People are following this question.
