Can the Multiplus 24v 3000W inverter charger also output 12volt? Thank you
@acmetiger No, as its charger is 24V DC and AC output either 120 or 230V AC depending on your model.What are you trying to achieve?
I'm sorry, @ejrossouw --I misstated my question (now revised). What I meant to ask is if the 24v 3000w Multiplus Inverter/Charger can handle either 12v or 24v input, or whether it can only run on a 24v battery (DC) system. Thank you for taking the time to reply.
15 People are following this question.
