Dave Rae avatar image
Dave Rae asked
Multiplus II 48/5000
Hello, During programming of the Multiplus II 48/5000 it has shut down by itself without me issuing any reboot command's. Disconnected the ethernet cable and then it's started up again say 15/20 second later. Pylontech battery voltage is fine, no recorded errors... Not sure what is going on, doesn't shut down any other time only when connected to pc.. Connection was through Victron Connect software and hardware is MK3 to usb adaptor... Cheers....
Multiplus-II
john-poul avatar image
john-poul answered ·
Drea, do you make connection with the USB MK2 / 3 in de PC or directly into the PC?
