jake-chapman avatar image
jake-chapman asked
Grounding Phoenix 12/250 inverter in a camper van
Currently, my Phoenix Inverter is grounded to the same point on my van's chassis as my leisure battery. This set up works and I've had no problems, though after doing some reading I'm wondering whether it is the safest or best way to do it.
If the leisure battery is grounded, does the inverter need to be grounded at all? Should the inverter always have its own ground? Any advice would be much appreciated.
Thanks,
Jake
Grounding
Ground, earth and electrical safety
