I use in the motorhome Can use the SmartSolar MPPT 100/30 to charge the body battery. Can I also use it to charge the starter battery.
Sabi, since nobody has provided an answer here, I am going to offer a solution. I don't think it would be wise to connect both batteries at the same time without careful consideration. However, if all you want to do is trickle charge the vehicle battery then that can easily be done by connecting a DC charger to the motorhome battery and setting a charge cycle to keep the vehicle battery topped up. I bought this https://www.ebay.de/itm/12V-24V-48V-6-60V-lead-acid-Batterie-Charging-Controller-Protection-Board-switch/322770295572?hash=item4b269bdb14:g:9o4AAOSwg0BZxNUl It charges the battery when the condition set up are true.
13 People are following this question.
