amartins avatar image
amartins asked
Why use Isolation transformer in automotive application?
From a Victron video on installing a solar on a van [1], in their setup they use a isolation transformer to connect the shore power to the inverter.
In what scenario this is usefull or required?
Thank you.
[1] Victron VW Van Electrics Install - Episode 1 Solar [link]
Isolation Tranformer
wkirby avatar image
wkirby answered ·
This is so that the van can use it's own earth system even if it is connected to shore power.
amartins avatar image amartins commented ·
Why should I want to have a separeted earth system on a van?
wkirby avatar image wkirby ♦♦ amartins commented ·
Once the van is plugged in to shore power then the MultiPlus N-E relay is open. Now your earth reference is no longer local on the van but it is back down the power line somewhere wherever the N-E bond is, it might be far away.
Also, if you use a floating generator without a N-E bond then you are isolated from that and you still have a reliable earth reference inside the van.
