houser avatar image
houser asked
NPM and node.js on Venus GX? good idea?
I maintain an off-grid victronssystem in the wilderness. Energy is very low at times..
Want to run some lightweight node.js stuff there and keep power consumption at a minimum. Probably end up on a RPi but would be even better if it can be run on the Venus GX itself. I assume this is a bad idea but asking the ask seemed worth it.
Probably at least this:
https://www.npmjs.com/package/homebridge
Any comments?
Venus GX - VGX
Excellent idea! And we're working hard on it. Test images available here, scroll to the bottom: https://github.com/victronenergy/venus/issues/378
houser avatar image
houser answered ·
Thanks @mvader,
You guys are constantly doing cool stuff in the general direction at least I want!
So is this a good time to jump in and start testing?
I assume I should start with your test images and go from there then?
It seems they will have a version of node.js and npm in the data directory so safe for firmware upgrades?
So possibly ok to also try installing more npm plugins as in the link I gave?
I have links to Venus and Apple homekit up and running on my dev laptop but would love to move that over to the Venus GX..
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
hi @houser I've asked a colleague to answer these & followup questions. In the mean time, be aware that I changed your title to good idea, rather than bad idea ;o).
houser avatar image houser mvader (Victron Energy) ♦♦ commented ·
Thanks @mvader ;) I also asked a question about which node.js packages to go for in the link in the mod section you gave. I assume that's where this should go. Really look forward to giving this a go!
Scott Bender avatar image
Scott Bender answered ·
Hi @houser. We don't put nodejs or npm in the data directory. If you installed that homebridge stuff, you would have to re-installed after a firmware upgrade. You're configuration for homebridge would persist after and upgrade since it goes in ~/.homebridge which is in /data.
