Hello, I've ran into a problem with the mppt 250/100 tr-vecan model. Firstly the MPPT is up to date (running ver 1.05) as per the VictronConnect app. The MPPT goes into err 28 when the power reaches about 4000W then upon restart it works again for a bit and soon as it gets to 4000W the same error occurs.
I have 5 panels in series and 4 in parallel, with Voc = 45.6V and Isc = 9.45A. I used the MPPT calc to model the system and all specs were within range but got warning that I've over-sized PV generator by more than 30%. I figured this wasn't an issue and the MPPT will just max out at 100A and my voltage is within range (max 238V @12 degrees celsius).
But now due to the power stage error, I've had to reduce the system to 4 in series and 4 in parallel, and the MPPT works fine. Is it an issue to have 5 panels in series?
