alexandre-berman avatar image
alexandre-berman asked
Skylla-IP44 cable to Cerbo GX
Is my understanding correct that to connect Skylla-IP44 charger to Cerbo GX I need to use RJ45 cable ? It’s being referenced as VE Can, VE Bus and UTP RJ45 so I’m a bit confused.
Also, by connecting these devices I should be able to control Skylla charger through Cerbo GX remotely (on/off) ?
Thank you,
Alex
VE.Can
Alexandra avatar image
Alexandra answered ·
Hello @Alexandre Berman I had a look around and yes it is a little confusing. We have yet to see a Cerbo this end of the world. But I do know VE CAN is used on the Color Control to connect to the Skylla, you can check this in the CCGX manual.
Since the Cerbo and color control are both GX, it would be safe to assume they would use the same communication protocols on both devices.
https://www.victronenergy.com/media/pg/Cerbo_GX_Device_Manual/en/installation.html
The full picture for all the connections can be found in the link. Her is the section for the Skylla
alexandre-berman answered ·
Thanks very much Alexandra - but my Skylla is Skylla-ip44 - not Skylla-i, not sure if they have completely different wiring options. And still couldn’t find in the documents if I can control on/off functionality of my Skylla through RJ45 cable connected to Cerbo GX.
