mikael-trevik avatar image
mikael-trevik asked
BMV-700 GEL battery settings
I need help to set the parameters correct for my two Exide GEL batteries In my BMV-700.
They are charged with a MPPT solar charger, and also via my RVs internal charger.
2x85Ah
This is the settings that I use today, but SOC 100% to fast...
Is there anything not correct?
BMV Battery Monitor
Alexandra avatar image
Alexandra answered ·
When a BMV is first installed it says 100% SOC out of the box to what ever it is connected to.
So if your battery was not at 100% when you connected it it will be out of sync. After a cycle or two it may re sync.
Do you have the datasheet for the batteries?
The settings that do affect the drift will be the charge detection time - maybe increase it and the tail current. Have you watched this video
https://www.victronenergy.com/blog/2017/04/13/instructional-video-how-to-optimise-the-bmv-700-series-sync-parameters/ ?
Not knowing more about your particular batteries there is no way to know specific settings to do with float Voltage
