I have just put the BMV 712 smart into operation.
I use the 10m cable to the shunt which was included in the package.
When I measure the voltage on the shunt (between B1 and ground) I get a correct value (in this case 13 Volt).
But the BMV 712 only shows 6.6 Volts and the display flickers (apparently the voltage is too low for operation).
I checked the cable to the shunt, the cable between B1 and battery plus and the fuse contacts. Everything seems to be ok.
What could be the problem here?
How can I solve the problem?
Thanks a lot
warm greetings
Martin
