Hi Jakob,
You can see the solar charge controllers that are compatible with 36V battery banks on this page underneath the model numbers.
https://www.victronenergy.com/solar-charge-controllers
Generally speaking it is the 150V models that are compatible.
The 100/50 is limited to 12 and 24V
Thank you for the info. I was confused, because in MPPT 100-50 manual is written at 3.5 configuration: fully programmable charge algorithm (see the software page) and at 5. specifications: charge voltage: 14,4 V / 28,8 V / 57,6 V - adjustable -
Thank you for letting me know Jakob. This is a mistake and I will have it fixed.
4 People are following this question.
