Dear Victron-Team,
Dear Victron-Team,
Because you are using the VE-BMS in the system and the assistant.
Then Currently the remote switch will not work, even if you had a GX device the remote on/off in that device is also disabled. ( I have been told that this draw back will not be changed)
you can only use Victron Digital Multi Control (DMC)
As a possible solution. you could to Install the DMC behind the dash and connect a second on/off/on switch to the DMC switch's connection points and thus extend this to were you want to mount the switch.
Sorry I cant be more helpfull
14 People are following this question.
