jrrujano avatar image
jrrujano asked
Problem when connecting MK2-USB with Quattro
When the MK2-USB is connected the operating Quattro 48 | 5000 | 70-100|100 120V turn off and it can not be turned on again even using the switch. When the MK2-USB is disconnected the equipment turns on normally. Does any one know what can be happening?
ejrossouw avatar image ejrossouw commented ·
Don't forget to disconnect other devices from inverter like the cgx
peter-zmg avatar image
peter-zmg answered ·
Hi, You must connect to the Quattro only after you have connected the MK2-usb to your PC and have the Config software running.
