lajo1976 avatar image
lajo1976 asked
Orion-Tr or Orion-Tr Smart DC-DC charger for charging Lifepo4 batteries
Hi, I want to charge my supply battery (LifePo4 12V100 with BMS) in my boat. I have an Mercury 75 Hp outboard with a regular lead acid as starter battery
I have looked at the Orion-Tr or Orion-Tr Smart DC-DC. I don't need the BT function as in the Smart DC-DC charger (my litium battery has a BT function ). I know the Orion Tr is just a DC-DC converter but would be fine to use as a charger for my Lifep4 battery which wants CC/CV charging. Looking at the Smart charger it has the 3-phase charging steps but I don't know what benefits it would be for my litium battery?
Any pro/cons for the Orion Tr agains Orion Tr Smart?
/Joakim
battery charging
JohnC avatar image
JohnC answered ·
Hi @lajo1976
They may look and sound much the same, but in reality they're quite different devices.
You may not care for BT, but the alternative means adjusting the V output with a tiny screwdriver, testing that with a multimeter, and disconnecting it from the batt while doing so. And you'll get a stable one-level V.
If you (and your batt) can live with that, then fine. But remember one was designed as a dc/dc converter, the other to charge batts.
Up to you to decide whether you can wear the inconvenience.
lajo1976 avatar image lajo1976 commented ·
Thank you John.
Yes the non smart series it is not deticated charger but my regular 230 V Lifepo4 charger just deliver constant current and voltage so it shouldnt be a problem.
Regards Joakim
