A customer has two SmartSolar MPPT 250/85ยดs each connected to 3 strings of 5 x 320 W 37(46) V solar panels that do not start up, blue LED blinks slowly. Voltage on PV input terminales is zero volts, but when connection is opened the solar panels show 207 to 214 Volts. On closing the switch PV terminals show zero volts. The PV input of the MPPTยดs seems to be in short circuit. MPPT shows no PV current, I asume because measuring is behind the short. Can this be repaired ?
