lauri-jalonen avatar image
lauri-jalonen asked
Victron BMW-600S with Raspberry and VenusOS?
I purchased VE.direct to USB cable to connect BMW-600S battery monitor with Raspberry, but there is not VE.direct connector on BMW-600S battery monitor. Can I somehow connect BMW-600S with USB cable to Raspberry with VenusOS by using PINs which are available on BMW-600S device?
BMV Battery Monitor
nebulight avatar image
nebulight answered ·
I think the 600s has BMV-60xS Text (TTL) according to this:
https://www.victronenergy.com/upload/documents/Whitepaper-Data-communication-with-Victron-Energy-products_EN.pdf
You might just need an adapter for the pin layout to the VE.direct plug.
Victron Part numbers are:
ASS030532215 is 1.5m
ASS030532230 is 3m
But that will only get you to ve.direct, which won't help with a raspberry pi. You might be able to make your own cable to USB:
https://beta.ivc.no/wiki/index.php/Victron_VE_Direct_DIY_Cable
Though I don't know the pin layout of the 60xS. However since you already have a USB to VE.direct, if you can get one of the above cables, maybe you can combine the cables with pins?
