brbrv avatar image
brbrv asked
BMV-712 Settings for 960ah of LiFePO4 with Victron MPPT 150/85
I am wondering if my BMV-712 settings are optimal for 960ah of LiFePO4 12v battery array and 1200 watt solar system using an MPPT 150/85 controller. Thank you!
BMV Settings for Solar:
Battery Voltage: 12V
Max Charge Current: 85A
Absorption Voltage: 14.5V
Float Voltage: 13.5V
EQ Voltage: 0.00V
Re-bulk Voltage Offset: 0.10V
Absorption Duration: Adaptive
Maximum Absorption Time: 30m
Tail Current: 2.0A
Equalization Current Percentage: 25%
BMV SOC Settings:
Battery Capacity: 960ah
Charged Voltage: 14.2V
Discharge Floor: 50%
Tail Current: 4.00%
Charged Detection Time: 1m
Peukert Exponent: 1.05
Charged Efficiency Factor: 99%
Current Threshold: 0.10A
Time-to-go Averaging Period: 3m
BMV Battery Monitor
Brian Knapp avatar image
Brian Knapp answered ·
Did you get this sorted out? I have two lifepo4 200Ah batteries and someone configured them just like yours. Are the settings correct?
brbrv avatar image brbrv commented ·
Everything but the discharge floor which should be 20%.
