fesolar avatar image
soc wrong around 50% ?
hy
i have a probleme with a bmv 700
one off my customer make a discharge test on a systeme with 24 V (2 bat agm 125Ah) .
he had fully charged individualy the batery before start the test.
the test start with a soc at 100 (on bmv and in real because the 2 battery was fully charged)
you can see below the test:
the probleme is he had just loking the soc and suddenly, all system broke done.
the theorical consumption is minimum 0.4A, the real cunsomption see by the bmv is 0.4 A
so if we calcul the Ah used, we arrived around 120Ah so it's look corect with the 125Ah off the battery, but the soc calculed by the bmv (around 50%)when shut down) is not good.
i had checked the bmv parameters, but it'look ok:
during the test there is only bmv, venus and the load conected and nothink conected between the batteri - and the shunt .
i don't anderstand why the soc is aproximatively 50% faults.
do you have an idee ?
best regards
BMV Battery Monitor
at first, i was thinking about this, but there's no multiplus an quatro in the system during the test only bmv and mppt.
i had just chek and the curve of the bmv soc is the same off the gateway so the information is comming from the bmv !
it's the first time a see this.
for information it's bmv firmwar is the v3.10, normaly it's the last one !
br
Share
John Hagtharp avatar image
My first suspicion is that your Venus device (ccgx etc) and therefore vrm might be using a different battery monitor, possibly the built-in monitor in a Multiplus or Quattro, which is configured with a different capacity. Have you confirmed during discharge that the SOC displayed on the BMV itself matches what you're seeing in vrm and on the Venus device?
Share
