So I'm seeing a need to apply certain tweaks to the CCGX which won't survive an update, has anyone used Ansible to apply these tweaks with a CRON job on another box? Are there any gotchas that I might be missing?
Hey @ElvisTheRV the solution are the rc.local and rcS scripts; you can put them on the data partition and they’ll be called on every boot.
see the root access document for details
I've been doing this for some time. One thing you should do is have your script check to see if it needs to apply the tweaks. Applying the tweaks with every boot is generally not harmful, it just takes time away from booting.
If you install additional files as part of your tweak, have the script test for the file's existence and skip the install if so. If you are replacing or modifying an existing file, then simply add a flag file and test for that.
Remember /data is preserved through a Venus update so put any flag file in another part of the system. I preserve any existing files I replace or modify and keep a copy of the original with .orig appended to the file name. I use this as the flag, but it also gives you a way to uninstall the tweaks.
https://github.com/kwindrem/TankRepeater
or
https://github.com/kwindrem/GeneratorConnector
Both packages use a similar setup script. The latter's setup script checks the Venus version and installs different files based on that. They both use "SetupHelper" which includes a mechanism to reinstall the mods after a Venus update
Feel free to reuse what you find useful.
18 People are following this question.
