vm70 avatar image
vm70 asked
Advice needed on AC-coupled Fronius Primo
Hi I have the following setup:
MultiPlus II @ 5KW on a 12KW Lithium battery.
AC coupled Fronius Primo 5 on output, MG50 setup, with PV inverter assistant, configured per this link:
https://www.victronenergy.com/live/ac_coupling:fronius .
On Fronius input I have a string of 10 solar panels.
System is monitored by Venus GX on VRM.
Here's the status:
1. VRM can see the Fronius ,
2. Fronius reports input voltage 410V, but input currrent ~0. Frequency 50Hz
3. Fronius status appears as Running("MPPT"), AC voltage 230V, current 0.1A
4. Battery ~ 50%
Looks like something is limiting the PV input, and/or AC output, but don't have any idea where to start the investigation.
Please advise,
Thank you in advance!
Fronius
