Hi
I have a blue solar mppt 100/30 and is outputting zero watts,the bulk charge light is solid blue but no current/wats into the battery
What could be wrong ?
Thanks
Hi
Thanks
This charger has no blade fuse, as far as I can remember, so what is your Absorption voltage set to?
If everything is set up right, maybe your charger is just broken...
Hi Markus
Thanks I’ll double check the settings
It’s charging a 100 ah agm battery from the 120 watt panel and day temps at the moment are about 30 degrees Celsius
Thanks
I found the problem with this controller,the internal fuse had blown once replaced it’s all good again
4 People are following this question.
