CristiMV avatar image
CristiMV asked
Generator on Multiplus AC-Out
Hi. My current system consists today in a Multiplus 48/5000, a Fronius Primo 8.2 (connected on Multi AC-out), and a Kipor generator which has its own ATS box....and a CCGX and a BMV710. As it is today put together (see below), it works quite well, the only issue is that I cannot control when the generator will kick in, not to mention to start it monthly as a proactive maintenance: Grid->Gen ATC AC-In; Gen ATS AC-Out->Multi AC-In; Multi AC-Out -> Primo & House. Would it work to change it and to have the grid connected directly to Multi AC-In, and Multi AC-out connected directly to Primo & House & Generator AC-Out, and via a 220V relay (which would be controlled by the CCGX relay) also the Generator AC-In? So when CCGX will decide to cut the generator AC-In and actually to start it. This would be an interim solution until I'll upgrade to a Quattro. Later edit: the schematics were added below
There are no html-skills required to make 2 clicks ;)
CristiMV answered ·
8397-img-0710.jpgThanks...my profile had "plain text" configured so I didn;t had that top menu. I've changed it now
CristiMV answered ·
So no idea from anyone?
This one is correct:
the other drawing: Don't do it! you will damage thing...
