oscarmax avatar image
oscarmax asked
MPPT SmartSolar MPPT begineer confusion
Hi I very new to all this and find it confusing.
Earlier this year I fitted a 75/15 SmartSolar and battery sense to my caravan, I have a newish wet 12v leisure battery, everything has been working fine, but the battery has always been fully charge, at this time of the year I am usually getting 2 to 3 watts. My caravan is fitted with a 80 watt mono solar panel
Yesterday I cleaned the caravan it was dirty under the panel so I used a small brush to clean, in the process I move the wiring connector out of the way. I had to move the caravan so had to use the caravan mover, this obviously took some energy out of the battery.
Now the App on my iPhone is reading 0 watts and 22v and is in bulk mode, this morning it was reading 0 watt and 20.9v in bulk mode, I have a fuse from the solar panel to the MPPT controller, I removed and replaced the fuse it went into absorption mode. I have just checked again it has gone back into bulk mode 0 watt 19.9 v. The voltage is charging. Though out all this the caravan battery is recording 12.84 volts.
Have I cause a problem with the solar connectors or all of this normal ?
MPPT Controllers
You might want to specify which voltage readings relate to the solar pv voltage, and battery voltage.
oscarmax avatar image oscarmax commented ·
Solar 20/22v caravan habitation battery readings 12.84v
Justin Cook avatar image
Justin Cook answered ·
@Oscarmax, usually a 0A reading from PV (under good sun conditions) is caused by either a blown fuse at the battery (since you should have a fuse at the battery on the POS line between the SCC and the battery) or reversed polarity at the SCC on the PV input - so those are things to check right away.
That being said, it appears that your battery is already full (12.84v), so that could easily explain what you're seeing as well. A way to test this will be to put a load on your battery (inverter or some other significant load) and see if your solar harvest current readings ramp up to compensate for the current out of the battery.
Also check the fuse at the MPPT itself. ;)
I finally solved the problem, it was a blown fuse to the caravans habitation battery, I had fitted a new fuse box and labelled the connection up wrong, I an feeling a bit stupid now. Anyway thankyou all for the help.
oscarmax answered ·
Hi Justin it is very overcast in the UK, I just assumed after using the caravan motor mover it would have used up some of the energy in my acid wet battery.
I will put some load on the battery tomorrow (hopefully we may have some sun) and see what happens.
Following advise from you guys on the forum I have made sure my controller, solar and battery are well fused and easily accessed.
oscarmax answered ·
We I put this system underload midday, I turned the ceiling extractor fan onto full blast, it draws about 3-4 amps. Solar panel fluctuating slight averaging 19.7v under load the caravan battery dropped down to 12.6 v, then not under load recovered straight away to 12.78v. Still recording 0watts
7 comments
Where do you read the battery voltage? VictronConnect? Can you make a screenshot or a photo?
Have you checked all fuses?
oscarmax avatar image oscarmax Matthias Lange - DE ♦ commented ·
I am using my iPhone Victron APP and the caravan display panel, I have checked all my fuses, and used my circuit tester at connection, I have a funny feeling when I cleaned the panels and move the connectors out of the way I may have created a poor connection.
oscarmax avatar image oscarmax oscarmax commented ·
I have just been out to the caravan with my tester, its is 2 pm in the UK overcast and raining, double checked the MPPT fuse ok, checked reading from MPPT solar connection terminals recording 19.6v, took a reading at the MPPT battery and load terminals 16.6v, still 0watts habitation battery using iPhone APP and caravans display 12.76v
Matthias Lange - DE avatar image Matthias Lange - DE ♦ oscarmax commented ·
Did you also checked this fuse?
yes I have checked its ok
Can you make a screenshot of VictronConnect?
No I am not that switched on
