wsconner avatar image
wsconner asked
75/15 mppt not controlling voltage?
I just installed the BT version of this controller with a 110watt panel. I updated the firmware. I'm charging a three battery bank of Northstar 31AGMs and set the bulk charge voltage to 14.7v and the float to 13.6v. The controller seemed to be workingas I was getting 14.5V and ~2amps (cloudy), but when it went from bulk (solid green) to absorption (solid orange), the battery were showing 15V+s (?). I would have thought the controller would have maintained voltage at 13.6v?
I took readings directly from the battery and the software app, and both had the battery voltage at 15v+. Any ideas are appreciated. thx.
MPPT Controllers
9 comments
Temperature compensation?
wsconner avatar image wsconner klim8skeptic ♦ commented ·
not sure I understand.. I am not using any temp monitoring..?
klim8skeptic avatar image klim8skeptic ♦ wsconner commented ·
Read page 5 & 10 of the manual.
yes and thanks for that resource. All I had was the spec sheet from Northstar. Now I understand..appreciate the help.
Jack Peters avatar image Jack Peters commented ·
Check the battery voltage setting is 12V and not 24V.
wsconner avatar image wsconner Jack Peters commented ·
I'll double check. When I set up the app, I made sure it was set to 12V along with the bulk and absorption rates for an AGM battery. Regaring ambient temperature, if I am understanding the concept correctly, I don't this could be the case. The 75/15 controller is mounted a few feet from the battery bank. The temp is ~50deg F. The panel however is on deck and the boat is shrinkwrapped in clear plastic (green house action), so the above deck temp was probably 70+ deg F yesterday. But again, sounds like ambient temp applies to the controller unit and the batteries.
From what I've read here..sounds like the software can be a bit buggy, so just curious if there are release notes or know defect lists anywhere?
"The 75/15 controller is mounted a few feet from the battery bank. The temp is ~50deg F. "
Note, the mppt will measure it's temp at sunrise, and apply that temp for compensation for the rest of the day.
Assuming you have not altered the temp compensation value (16mV/c), 50f would equal a 0.24v rise in battery target voltage.
ok, thanks very much. so the 16mV value in the compensation settings is the max bulk charge voltage that accounts for temp differences? If so, if I lower that value to my batteries recommend charge voltage (14.7) I'd effectively negate the purpose of the setting?
Does this match your battery? Northstar.
Please do your own calculations.
Hi @wsconner,
the MPPT controller has a temperature sensor built in. As far as I remember temperature compensation is set on by default at -16.2mV/°C. As soon as ambient temperature inside the housing of the MPPT drops below 25°C, temperature compensation is in effect. That might explain your higher voltage.
wsconner avatar image wsconner commented ·
Stefanie (Victron Energy Staff) avatar image Stefanie (Victron Energy Staff) ♦♦ wsconner commented ·
Exactly. When you set temperature compensation offset to 0mV/°C, there is no temp compensation and the feature is disabled.
wsconner avatar image wsconner Stefanie (Victron Energy Staff) ♦♦ commented ·
Ok, makes sense now. appreciate the help. thanks.
