The VE bus system cannot be seen on the device list and hasn’t been seen for at least 24 hours now. What do I do? The firmware is up to date.
Hi @Ray
You could try a reboot of the GX.
If that doesn't work, try reseating the VEBus cable at each end and/or changing it out completely. It's just a standard 'ethernet' cable.
There are Redetect/Reset options for the inverter in Remote Console, but I suspect you can't reach them.
But come back..
12 People are following this question.
