How many 100w solar panels can I hook up to a 100/20 MPPT SCC for 12v system?
That charge controller can make nearly 300W maximum on a 12V nominal system (20A x 14.4V = 288W) . So 3x 100W panels would be good for it.
You should be fine wiring all three in series, but we don't know the exact specifications for you panels, so it is difficult to say for how you should configure the wiring.
Please could you let us know which solar panels you intend to use then we can give you a better answer.
13 People are following this question.
