Hi, the image from inside is stating Firmware 2661430.VFD. This couldn't be found on the Firmware updates page. Which version should I use and why is the firmware ending with VFF on the site? S/N HQ1911G****
If you use Victron Connect it will find the correct firmware for you and update it. Much easier for the end user and less chance of errors.
https://www.victronenergy.com/support-and-downloads/software
https://docs.victronenergy.com/victronconnect-vebus.html#firmware-updates
I am assuming you already have equipment for connecting to the Inverter for the update.
The Victron Connect will only update the Connect software not the device.
Could you please explain this a bit further?
Did you attempt to update the multi’s firmware in VictronConnect and it failed somehow?
Did you follow all the steps of the documentation -
15 People are following this question.
