kaarthik avatar image
kaarthik asked
mppt output fluctuation
i was installed mppt with pylontech battery , i was noticed the production in a mppt was not stable its produced 200w then 500w then 300w then 100w then 800w so on , total installed capacity is 1200W. i was changed two mppt 150/35.still its gives same performance.my battery soc is 30% to 50% during the production.here below i was attached the image.
MPPT Controllers
wkirby avatar image wkirby โ™ฆโ™ฆ commented ยท
Do you have the graph of battery Voltage at this same time period. Do you have other charging sources in the system?
0 Likes 0 ยท
petajoule avatar image petajoule commented ยท
Any clouds on the sky? Which MPPT model? Any error messages in the MPPT?
0 Likes 0 ยท
