Good day,
is the BMV-700H compatible with the LG Resu 10H battery, which has an extended voltage of 350-450V when used in SolarEdge?
Good day,
@Beny, unfortunately the 700H can only work with 60-385vDC according to the user manual, so it does not appear that it will work with your battery bank if the voltage range you give is indeed accurate.
Die Daten sind korrekt :-(
@Beny, du hast recht, leider funktioniert der 700H nicht für dich :(
12 People are following this question.
