Michael Connolly avatar image
Michael Connolly asked
712 shunt power pin removal
I need help on how to temove the positive battery connection on the shunt of the 712. I am swapping the simple power connector cable for the thermometer which uses the same pin connections. Tried pulling the pin but no joy. Tried lifting the yellow thing on top of the pin connector on the shunt but no joy!!! Anyone able to help???
BMV Battery Monitor
wkirby avatar image
wkirby answered ·
You need to push the orange tab down towards the PCB and then pull the wire out.
A very small flat head screw driver makes this easy.
