swoodcock11 avatar image
swoodcock11 asked
Unable to re-enable bluetooth on MPPT 75 10
My device just updated to v2.23 from v2.19 and also v1.46 from v1.42.
I then chose to disable Bluetooth so I could monitor the "self" current consumption.
I have followed the instructions to re-enable Bluetooth but the smart solar charger is not seen within the 30s for which Bluetooth is said to come back on e.g. following a power off/power on event.
How else can I re-enable Bluetooth?
MPPT Controllers
pau1phi11ips avatar image
pau1phi11ips answered ·
You could plug it into a laptop with a VE direct to USB lead.
swoodcock11 avatar image swoodcock11 commented ·
Ok, thanks, another 25-£30!
Hi @swoodcock11,
Apologies, the manual was not clear that the 30s reset feature only applied to the Smart Range of 240V battery chargers, not the MPPTs.
I have now updated the documentation to make this clearer.
I have also asked the app developer to make this clearer in the app itself, at the time of disabling bluetooth, that an additional USB accessory is required to re-enable.
Please check your email.
datsports avatar image datsports commented ·
hi , i have accidentally switched off my bluetooth on one of my 100/50 mppt smart controllers , trying to turn off instant readout switch ,i turned off the bluetooth enabled switch via victron connect ios app . .and switched the wrong switch .
the bluetooth turned off i'm sure i saw no warning note .
it just turned off and is now gone from my device list .
can i turn this function back on via cerbo GX ?
the mppt wont reset with a reboot what options do i have . thanks
klim8skeptic avatar image klim8skeptic ♦ datsports commented ·
@Datsports Yes you can remotely enable the bluetooth via Victron Connect via VRM.
Connect & Configure Remotely in the Latest VictronConnect Update
Should Victron Connect beg to update the mppt ignore it. Go to settings > 3 dots right hand top > product info > enable bluetooth.
Dontdoitagain ;) .
Forgot the money shot.
