Jacob avatar image
Jacob asked
Where's the current going?
My MPPT 100/50 says it is sending 14A to the batteries. My clamp meter confirms ~14A in the cable right at the controller. At the battery, my clamp meter shows 5.5A. Shouldn't I be seeing the same current in both places? Does this indicate a current leak somewhere? What else could cause this? Thanks for any suggestions on tracking down the cause.
MPPT Controllers
JohnC avatar image
JohnC answered ·
Hi Bob. If you're measuring under the same V (or close) then A can't just disappear. It must be heading off to a dc load, or even a short circuit (look for generated heat).
Even kit turned off may have a standby draw, so watch for that.
You could also try measuring the A on the -ve earth return to see if you can find some sense in that part of the circuit.
But yeh, stay concerned until you find out where it's going.
Jacob avatar image
Jacob answered ·
Thanks John
