jorvik-rose avatar image
jorvik-rose asked
MPPT Connection question
I have a Quattro 3KW system with shore power and generator input. The system is wired through a DC link box. I am looking to add a 150w solar panel and a Smartsolar MPPT 75/15. My questions are:
Can I connect the MPPT battery output to the battery side of the link box or should I connect it directly to the battery?
Where do I connect the load terminals on the MPPT? I noticed that the larger MPPT controllers don't have a load connection, so do I simply leave these without connection?
Many thanks,
Christian
MPPT Controllers
Warwick Bruce Chapman avatar image
Warwick Bruce Chapman answered ยท
Please post a photo of the link box but ideally directly to the battery - or as close to it as possible to reduce losses as a result of resistance.
The load output on the MPPT is probably not necessary in your setup - you would use it if you has something like a 12V fridge or similar that you wanted to power directly from the MPPT. You will see that only the smallest MPPTs have this feature, the larger ones do not.
jorvik-rose avatar image jorvik-rose commented ยท
unfortunately i'm not near the installation for a few days. It is Victron DC linkbox installation, was thinking of connecting to the battery positive connection on left hand bus bar as its the easiest and only about 600mm from the first battery.
0 Likes 0 ยท
