My current firmware is 2702413.HEX
What firmware is presently available ? and what has been changed..?
Also where can I download it if I need to update..?
Hi RayH,
you should be able to find the respective firmware under
https://professional.victronenergy.com/downloads/firmware
Groeten - tullsta
my inverter is a multi 12/3000/120, running firmware 1909140, so on the professional site what file should I look for,any help appreciated.
thanks in advance
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
The first 4 digits are to identify hardware model and the last 3 are the firmware version. So the first 4 digits have to match with the file you have to download.
There is a pdf with better explanation liked in the manual above.
6 People are following this question.
