Blue Solar MMPT 75/15 = Updated latest update on my App Im unable to get a Watts reading and no Histogram, I can only see and read a Voltage reading what would could cause this issue of not showing the Watts ......
Hi M. Lange thank you for your prompt response ...
13.79 Battery Voltage and PV Voltage 21.01
Mobile Phone Samsung S7
13.8V is the float voltage.
Can you measure the voltage directly at the battery?
What happens if you disconnect the PV panels?
My guess is that there is a blown fuse between the MPPT(there is a fuse directly at the MPPT) and the battery.
14 People are following this question.
