s-v-simbora avatar image
s-v-simbora asked
Skylla IP44 - User relay programming
I am trying to program my Skylla IP44 I just bought, especially the User Relay. In the manual, p.7 par. 2.5.4. it states "The user relay is triggered by an under-voltage situation." But then it goes on to give 9 different options for relay modes.
How does the first statement tie in with the different modes? If I choose mode #7(Battery voltage high) how will this relay behave? Does the first statement not apply then anymore?
It seems very confusing and the literature seems to contradict itself. Or am I interpreting it wrong?
Please help.
Skylla
As I understand it if you choose #7 the relay will only switch if the voltage goes to high(setup 14/15).
At #0 the relay is closed until the voltage goes to low(setup 12) or to high(setup 14) and will open if the voltage gets higher(after low - setup 13) or lower(after high - setup 15).
#3 is only for low voltage.(setup 12/13)
s-v-simbora avatar image s-v-simbora commented ·
I agree. That's how I understand it as well but is it correct? Why then did they put the statement in that reads: The user relay is triggered by an under-voltage situation."? Is this the default mode (#3), or something like that?
