jimmy-henningsson avatar image
jimmy-henningsson asked
Quattro multiplus digital input spec
Hi.
I have a system on 3 quattro 10kw in a 3 phase system, solar chargers, BMV, wind generator, CCGX and will now install a litium battery.
I have 2 questions:
1: I cant find any spec on the digital inputs that is on the quattro in the manual. Are they 0-5V analog, 24/48VDC digital, both? (for the BMS control of the quattro)
2: i want to se the charging of the wind generator in the CCGX, like i se the solar charging separate from everything else.
Today i use the funktion "Has DC system" in the CCGX but it must be a better way for this?
Hi @Jimmy Henningsson
1. the digital inputs are indeed 0-5v, and when a input is pulled to 0v it is registered as 'closed'
2. unfortunately no other way to visualize this wind input in the CCGX
