bos avatar image
bos asked
Multiplus II grid code
Have been getting the PE2 closed error or GND Relay Error as per below.
https://www.victronenergy.com/live/ve.bus:ve.bus_error_codes#error_11_-_relay_test_fault_-_installation_error_or_possibly_relay_failure
After updating to the latest firmware 2623467 I now require a password to change any settings at all.... have just lodged a service report but unsure as to how quickly I'll receive a response.
I am looking to setup as per below post:
https://community.victronenergy.com/questions/1702/multiplus-with-generator-and-residual-current-devi.html
"This link requires there to be no MEN in any connected generator and the internal ground relay inside the Multiplus inverter charger to be DISABLED."
Any help in getting the grid code promptly would be appreciated.
Cheers
Multiplus-II
Rob Duthie avatar image Rob Duthie commented ยท
Hi
You have to get the grid code from a dealer only, they will not release it over this forum etc.
Regards
Rob D
NZ
0 Likes 0 ยท
