jeffreyb avatar image
jeffreyb asked
Smartsolar 100/30 no panels show .01V
Just installed Smartsolar 100/30 with no panels hooked up. (Nothing connected to pV’s) also have networked BMV 712 with temp sensor. With no panels the voltage under solar shows .01 volts.
Should I be concerned about this? I have read a previous poster after reading all night about this but he had panels hooked up with a fuse.problem.
Here no pv connections.
Any insight regarding this?
thank you
MPPT Controllers
Elimac avatar image
Elimac answered ·
In my opinion this is completly normal. I'd be more concerned if you saw amps going in, not voltage. Small voltage can appear for a number of reasons, namely because of parasitic capacitance in input stage mosfets.
Justin Cook avatar image
Justin Cook answered ·
@JeffreyB, this is only 1/100th of 1 volt that it's showing, so there's nothing to worry about here. Given that the "pv" and "battery" terminals aren't fully isolated from each other, a little ghost voltage between the input/output is entirely normal to see when one or the other isn't connected.
